3.3 TT noise on cold startup from high pressure fuel pump is it normal (knock)
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by HORNET, May 11, 2018.
  1. HORNET
    HORNET Newish Member
    13
    2
    I hear this low knock on first starting up and it gets a little louder after a while.It lasts about a few minutes and slowly disappears as the engine rpm returns to normal.I located it's source and it's coming from the high pressure fuel pump next to the engine on the drivers side.After restarting during the day no noise .Is this normal for this high pressure pump to do?
  2. Kamauxx
    3,178
    1,255
    On cold starts the ECU pumps more fuel to the air/fuel mixture. The ECU also makes the car idle at a higher RPM.
    It's normal for your car to make all kinds of noise when initially started after cooling off. It's also normal for it to start up quieter throughout the day.
    • Like Like x 1
  3. Tbatten
    Tbatten United States New Member
    4
    2
    Yeah that scared me too. Took mine back to the dealer ready to lose it. They held it overnight to get a cold start. Used a stethoscope, sent it to techs. Then checked the others they had on the lot. It's the same with them all. They said it's normal on cold starts and wont cause any problems.
    • Like Like x 1
  4. HORNET
    13
    2
    Thanks much appreciated
  5. Dspec 1
    Dspec 1 Canada Member
    44
    21
    Mine just started doing this after the first oil change. Good to know.
  6. StingerNYC
    StingerNYC United States Active Member
    292
    166
    Queens, NYC
    It's the high pressure fuel injectors. Very normal.
    • Like Like x 1
Draft saved Draft deleted
Share This Page
