2018 Stinger leaking fluid from rear of vehicle
Dylan M
Noticed two small puddles of light brown fluid on the driveway from the rear center of the vehicle. Thinking this might be differential fluid. Any advice ?Stinger-Leak.webp
Well, look at the bottom of the car? Spray it off thoroughly and keep watch? Then get it in for a diagnostic.
Hard to tell when its mixed with water, smell it. You should be able to tell immediately if its gear oil.
the smell is super distinctive for gear oil.
plus, a leaking diff is obvious as hell when you look at it
