2018 Stinger fueling problem
not2high2fly
When pumping fuel if I pull the lever on the hose handle all the way back for fastest fueling it will let me put a few gallons in and then click off, it's like the tank can’t vent fast enough does anyone else have this problem? I’m sorry if this post is not in the correct forum. Thank's for your help
how odd that you want to use the full position. it isn't necessary. the first holding position is very fast everywhere that I've filled up for years, with one exception last year where the pump was on the fritz.
Has it done this since new?
When did it start?
