Stump-1 Newish Member Joined May 26, 2020 Messages 11 Reaction score 4 Points 3 Aug 14, 2020 #1 Is it OK to keep gap at .024 or should I reduce gap to .022?
S SOCAL2.0 Active Member Joined Apr 10, 2018 Messages 156 Reaction score 43 Points 28 Aug 15, 2020 #2 my 2 cents worth is that on your 2.0 will run well with the larger gap. If you modded your engine then a new plug may be needed. If your running a stock engine then go with what your manual calls for!
