144G13LA0B 208 Stinger AWD engine.
SirJag63
I'm looking for a replacement motor for my stinger we just bought used. I have oil in #6 cylinder and wanted a short block but none out there in the USA. I have seen used motors but we only have 13,600 on engine. Does anyone have one available with low miles for sale?
Thanks
John Green
Have you done a compression and/or leakdown test on the engine?
Oil in the cylinder is usually a sign of a valve oil seal failure..hardly grounds for an engine replacement...especially at the cost of the 3.3 l if you can find a good used one. How do you know there is oil in the #6 cylinder? I would do alot more troubleshooting before I jump on the replacement train...the cost in labor alone for replacement would be crazy.
